10-07-2009 07:01 AM - edited 07-03-2021 06:07 PM
Our Wireless configuration is all installed serving our main campus connected to diferents switches. we have 6 AP in 3 building all interconnected and 2 of them always show up as connected but Administrative Down, so the 2 AP can be managened from the WLC but are not broadcasting the SSIDs or allowing any connection.
We also upgrade to the latest AIRONET OS (6.0) and reconfigured the WLC and all stayed exactly as before, 2 out of 6 AP are Admin Down.
Any help will be appreciate it.
Solved! Go to Solution.
10-08-2009 06:06 AM
Please rate my answer and mark as solved. Thank you.
10-07-2009 12:30 PM
Are you using PoE from the switch or injectors?
10-07-2009 02:44 PM
Injectors
10-08-2009 05:56 AM
Go to configure AP's and check setting for Power over Ethernet Settings. Make sure Power Injector State is checked.
10-08-2009 06:03 AM
Thanks, yes, re-registering the injectors solved the problem.
Apprecited
10-08-2009 06:06 AM
10-08-2009 06:07 AM
Done!!
