Community Member
2 SSID's-1 not broadcasting and no encryption
We use an Aironet 1220 AP. We have 2 SSID's, 1 with 802.1x and the other we want to not use any encryption and this one will not broadcast. The 802.1x SSID uses WEP for encryption. The firmware is 12.3(8)JA2. Is it possible to do have 2 SSID's, 1 with encryption and 1 without? If so, how can we achieve this?
Community Member
Re: 2 SSID's-1 not broadcasting and no encryption
Hi carnold5.
The easiest/best way to do this is to have two VLAN's. Set the switch port to a trunk with both VLAN's on it. Then tie each SSID to one of the VLAN's. You can then have multiple SSID's with different encryption settings and they won't interfere at all.
Hope this helps!
Community Member
I have a similar scenario, I have Cisco 1200APs and I would like to configure one SSID with security and one without, but both must be on the same VLAN. (We have a BlueSocket box handling authentication, but we want staff connections to be encrypted, but still have open access)
My configuratin currently looks like this for the radio:
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid Staff
authentication open
authentication key-management wpa
wpa-psk ascii 7 *******************
ssid Students
authentication open
guest-mode
Thank you,
Chris
Silver
Unfortunately, there's no way to link 2 SSIDs to a single VLAN using autonomous access points. You can do this using the lightweight architecture, but that won't help unless you upgrade your entire network.
The only solution here would be to place two access points in close proximity to each other, each with a different SSID for your VLAN. Not exactly a clean solution.
Community Member
The 2 APs is not possible, I have heard that it is possible to do it with 2 SSID mapped to two different VLANS, each with its own encryption. Is that true? If so I think I may be able to make it work.
Community Member
Ok... I got as far as configuring it on the access point and I was able to get one of the SSIDs to go all the way through to our appliance, the unsecured "Student" SSID. Here is my configuration, am I missing something?
Also on the switch I have a dot1q trunk configured. VLAN 90 is the staff wireless VLAN and vlan 91 is the student wireless VLAN.
dot11 ssid Staff
vlan 90
authentication open
wpa-psk ascii 7 *****************************
dot11 ssid Students
vlan 91
authentication open
guest-mode
username hec privilege 15 password 7 **********************
bridge irb
no ip address
no ip route-cache
encryption vlan 90 mode ciphers tkip
ssid Staff
ssid Students
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
station-role root
rts threshold 2312
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.90
encapsulation dot1Q 90
no ip route-cache
no cdp enable
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface Dot11Radio0.91
encapsulation dot1Q 91
no ip route-cache
no cdp enable
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface FastEthernet0.90
no ip route-cache
bridge-group 3
interface FastEthernet0.91
no ip route-cache
bridge-group 2
270
