Community Member
2106 and 1510
I am unable to access the 2106 via the gui. HTTPS://(IP Address). Does anyone have any tips on what I should check on the CLI to be able to access the 2106 via the browser? CDP Neigh sees it but unable to get a reply back when ping is issued.
1 REPLY
Re: 2106 and 1510
Hi Carlo,
So you cannot ping your controller at all from machine which is in same subnet as your managent interface on controller?
Have you already configured your controller with managemet interface and its ip address?
For HTTP and telnet access you have to issue this command
config network webmode enable
config network telnet enable
Ankur
135
