2504 WebAuth and IPv6 RADIUS Accounting (IPv6-Framed-Address)
Hi Board,
I'm playing around with RADIUS Accounting in combination with local web authentication on the wireless LAN controller.
So far so good - everything works well, but I'm missing the "IPv6-Framed-Address" in the RADIUS accounting messages.
The only thing I can see is the v4 framed IP address and the "Framed-IPv6-Prefix". According to the configuration guide
http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-0/configuration-guide/b_cg80/b_cg80_chapter_0101001.html#ID807
the "IPv6-Framed-Address" should be sent by the WLC. I took a capture on a span port of the WLC to verify this. Anybody else experiencing this behavior or is it a simple misconfiguration on my side? In the client details I can see the global IPv6 addresses and the link-local.
I tested it on a WLC 2504 with 8.0.100.0 code.
Cheers
Johannes
1 REPLY
Late reply, but hopefully of
Late reply, but hopefully of use. You'd need the following config to send both attributes:
config wlan radius_server acct framed-ipv6 both {wlan number}
206
