05-07-2014 01:18 PM - edited 07-05-2021 12:47 AM
Access Point is not joining WLC. New deployment.
This is console info from AP:
=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.05.07 15:20:48 =~=~=~=~=~=~=~=~=~=~=~=
Not in Bound state.
*Mar 1 00:02:50.863: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar 1 00:02:53.935: %CAPWAP-3-ERRORLOG: Invalid event 40 & state 2 combination.
*Mar 1 00:02:54.063: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.129.100, mask 255.255.255.0, hostname APd072.dce5.f444
*Mar 1 00:03:00.863: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar 1 00:03:10.863: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'CISCOCONTROLLER'running version 7.4.121.0 is rejected.
*Mar 1 00:03:10.863: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar 1 00:03:10.863: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar 1 00:03:10.863: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar 1 00:03:10.863: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 192.168.129.252
*Mar 1 00:03:20.863: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'CISCOCONTROLLER'running version 7.4.121.0 is rejected.
*Mar 1 00:03:20.863: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar 1 00:03:20.863: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar 1 00:03:20.863: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar 1 00:03:20.863: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 192.168.129.252
IOS Bootloader - Starting system.
flash is writable
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 12 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 7354880
flashfs[0]: Bytes available: 33803776
flashfs[0]: flashfs fsck took 10 seconds.
Base Ethernet MAC address: d0:72:dc:e5:f4:44
Ethernet speed is 1000 Mb - FULL Duplex
button is pressed, wait for button to be released...
button pressed for 19 seconds
process_config_recovery: set IP address and config to default 10.0.0.1
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx"...##########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Boot CMD: 'boot flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx'
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"...######################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx" uncompressed and installed, entry point: 0x1003000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3700 Software (AP3G2-RCVK9W8-M), Version 15.2(4)JB1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Sat 16-Nov-13 10:46 by prod_rel_team
Initializing flashfs...
flashfs[2]: 12 files, 2 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 7354880
flashfs[2]: Bytes available: 33545728
flashfs[2]: flashfs fsck took 10 seconds.
flashfs[2]: Initialization complete.
flashfs[3]: 0 files, 1 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 11999232
flashfs[3]: Bytes used: 1024
flashfs[3]: Bytes available: 11998208
flashfs[3]: flashfs fsck took 1 seconds.
flashfs[3]: Initialization complete.
Copying radio files from flash: to ram:
%Error opening flash:/ap3g2-rcvk9w8-mx/E2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/B2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/V2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/X2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/Y2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/R2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/Q2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/C2.bin (No such file or directory)
Uncompressing radio files...
File not found: flash:/ap3g2-rcvk9w8-mx/8004.img
File not found: flash:/ap3g2-rcvk9w8-mx/E5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/B5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/V5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/X5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/Y5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/R5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/Q5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/C5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/8006.img
...done Initializing flashfs.
no ip http server
% Invalid input detected at '^' marker.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP3702E-A-K9 (PowerPC) processor (revision A0) with 204790K/57344K bytes of memory.
Processor board ID FTX1815736K
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.6.1.118
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: D0:72:DC:E5:F4:44
Part Number : 73-15397-01
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC180977J9
Top Assembly Part Number : 068-05055-01
Top Assembly Serial Number : FTX1815736K
Top Revision Number : A0
Product/Model Number : AIR-CAP3702E-A-K9
% Please define a domain-name first.
Press RETURN to get started!
APAVC: Initial WLAN Buffers Given to System is 2500
APAVC: WlanPAKs 18174 RadioPaks 17566
set_radio_pwr_mode: bad radio unit# 0
set_radio_pwr_mode: bad radio unit# 1
*Mar 1 00:00:13.683: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar 1 00:00:15.755: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:16.119: %SYS-5-RESTART: System restarted --
Compiled Sat 16-Nov-13 10:46 by prod_rel_teamset_radio_pwr_mode: bad radio unit# 0
*Mar 1 00:00:16.231: %CDP_PD-4-POWER_OK: Full power - HIGH_POWER inline power source
*Mar 1 00:00:16.239: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar 1 00:00:16.239: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default configlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:00:16.363: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:17.203: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to upERROR: Failed to configure ethernet promiscuous mode. Interface Descriptor mismatch
*Mar 1 00:00:21.039: DPAA Initialization Complete
*Mar 1 00:00:21.039: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar 1 00:00:22.039: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
no bridge-group 1 source-learning
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar 1 00:00:34.911: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar 1 00:00:49.915: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 192.168.129.100, mask 255.255.255.0, hostname APd072.dce5.f444
Translating "CISCO-CAPWAP-CONTROLLER.crownpartners.local"...domain server (192.168.123.84) [OK]
*Mar 1 00:00:59.859: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar 1 00:00:59.863: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'CISCOCONTROLLER'running version 7.4.121.0 is rejected.
*Mar 1 00:00:59.863: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar 1 00:00:59.863: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar 1 00:00:59.863: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar 1 00:00:59.863: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 192.168.129.252
Solved! Go to Solution.
05-07-2014 01:30 PM
3700 require min 7.6.x software on your WLC. Upgrade your WLC to 7.6.120.0 (MR2)
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#56735
Currently you are running 7.4.121.0 & Discovery messaged rejected by WLC
Rasika
**** Pls rate all useful responses. Each time you rate a response Cisco will donate $1 to Kiva ****
05-07-2014 01:30 PM
Rasika
05-09-2014 07:05 AM
Thank you, this resolved my problem.
But, I am very disappointed that Cisco REQUIRED me to purchase a service contract before they would allow me to download the latest version of software. This was a brand new device, just purchased, and they would not provide the latest software for free. TERRIBLE business practice! I even escalated my anger to a supervisor on the phone and they would not budge on this policy. I certainly will not consider Cisco for my next purchase.
05-09-2014 03:13 PM
Hi Tom
Sorry to hear about that
When purchasing WLC, always check what software version comes with it. When we place the order with Cisco, BoM should include the software version required. So whoever order on behalf of you may put the 7.4.x as the software version.
Rasika
05-09-2014 11:56 PM
Talk to the authorized Cisco vendor/reseller and ask them if they can provide you with the software.
There are some vendors/resellers who have access to the firmware and don't mind the request.
05-10-2014 08:35 AM
Well with any other vendor, they have a matrix of what code supports what hardware. Vendors also require you to have some support in order to download code. Just in case you decide to keep going with Cisco, here is a matrix that will show you what's compatible.
Please rate helpful post and Cisco Support Community will donate to Kiva
Scotty
