2600 AP continuosly reboots
I have a WiSM which manages 2600 LAP's. it seems when i add any new ones they join the controller, i can see the config is downloading but they then reboot and start again.
I rebooted the WiSM which seemed to resolve this but ive added some more and they are doing the same. I dont want to have to keep rebooting the controller.
has anyone had this issue before?
cheers
Bronze
If you have Wism , the last
If you have Wism , the last code supported was 7.0.X, for 2602 you need minimum 7.2.x or above.
Thank you
Rate this port if you find it hepful
VIP Purple
Hi Michael,I think its a bug
Hi Michael,
I think its a bug .
Dont know the exact bug number but may be this one: CSCum80710
also see the compatibilty matrix: http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Thanks for the repliesI
I upgraded the WiSM to support the 2602's.
The bug does seem possible but the matrix also shows we are using the most up to date version.
I have two WiSM's:
WS-SVC-WISM2-K9
ver 7.4.121.0
AP's
AIR-LAP1142N-E-K9
AIR-CAP2602I-E-K9
Prime
1.3.0.20
ISE
1.2.0.899
patch 6
The bug search does say this is fixed in ver 7.4(122.18) so I guess I need to try an upgrade
46
