2621 Upgrade failure
File reception completed.
TFTP flash copy: Error, image size (18070132) larger than flash (8388608).
rommon 14 >
Do I really need to buy/replace flash? Or I still have space in flash (after format:?), how can i check this from rommon> mode?
Please help.
Sylvester
Re: 2621 Upgrade failure
& If I reset, it gives me the magic number error.
rommon 14 > confreg 0x2101
rommon 15 > reset
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
C2600 platform with 24576 Kbytes of main memory
device does not contain a valid magic number
boot: cannot open "flash:"
boot: cannot determine first file name on device "flash:"
rommon 1 >
rommon 1 >
Note, main problem is space.!!! is there anyway to free the space in flash?or check the contents of flash from Rommon> mode - If not what is the alternative?
Cheers,
Sylvester
Hall of Fame Super Gold
Hi Sylvester,
Downgrade to an IOS which is <24mb flash requirement.
Thanks for the reply.
Earlier I was using c2600-js-mz.120-2.XC2, Since the router had VWIC-2MFT-T1-D1 card, i had to upgrade to IP Plus IOS which is c2600-is-mz.123-26.bin
If I downgrade to previous version, I will not able to use my Module. :(
Kindly suggest,
Sylvester
Or shall I upgrade the flash;
I think you need to add some flash to your router.
652
