Community Member
2851 NM-AIR-WLC6-K9 WLC showing Unknown
We installed a NM-AIR-WLC6-K9 into our 2851 and it is showing "Unknown".
Below is our IOS Version and the message.
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(21a), RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
System image file is "flash:c2800nm-advipservicesk9-mz.124-21a.bin"
Cisco 2851 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FTX0911C0T2
2 Gigabit Ethernet interfaces
1 Serial interface
2 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
8 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62592K bytes of ATA CompactFlash (Read/Write)
Slot 1:
Unknown (type 1283) Port adapter
Port adapter is disabled
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.0
Top Assy. Part Number : 800-27210-01
Board Revision : B0
Deviation Number : 0
Fab Version : 02
PCB Serial Number : FOC09400PKT
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Fab Part Number : 28-5683-02
Manufacturing Test Data : 00 00 00 00 00 00 00 00
Field Diagnostics Data : 00 00 00 00 00 00 00 00
Product (FRU) Number : NM-AIR-WLC6-K9
CLEI Code : COUCABMCAA
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 05 03 41 01 00 C0 46 03 20 00 6A 4A 01
0x10: 42 42 30 88 00 00 00 00 02 02 C1 8B 46 4F 43 30
0x20: 39 34 30 30 50 4B 54 03 00 81 00 00 00 00 04 00
0x30: 85 1C 16 33 02 C4 08 00 00 00 00 00 00 00 00 C5
0x40: 08 00 00 00 00 00 00 00 00 CB 8E 4E 4D 2D 41 49
0x50: 52 2D 57 4C 43 36 2D 4B 39 C6 8A 43 4F 55 43 41
0x60: 42 4D 43 41 41 89 56 30 31 00 FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
1 REPLY
Gold
Re: 2851 NM-AIR-WLC6-K9 WLC showing Unknown
The WLCM is supported under the T trains of IOS. You need to switch to one of the software trains that support this module.
382
