Community Member
302-08P and AP1041N a good fit?
I am replacing wireless for a local hotel. It is a 2 story building in a L shape, about 120 rooms. All cat5e cables have been tested and certified. I installed a 302-08P switch in the MDF and IDF and are uplinked via copper/gig ports. I am replacing some old WAP200s - 7 of them - 4 in one wing and 3 in another.
I'm looking at the AP1041N. It uses about 13 watts, and the 08P is capable of 62 total (15 per port). I believe that with these power considerations I will not be able to go w/more than 4 APs per switch which should be plenty. Otherwise I will need to upgrade to the MP switch or use some injectors.
I would love to get some feedback on the AP1041N as well as using it w/the 08P. Some reviews I have come across state that it has excellent signal strength. The APs will be located at the top of the 1st floor in a chaseway between the rooms. The current WAP200s produce pretty decent coverage, so I am thinking that the 1041 should blow it away. Any thoughts?
I know that wireless is finicky, but any chance that I could reduce the number of APs by upgrading from the Linksys WAP200 to the Cisco 1041?
Any other comments, thoughts or ideas would be appreciated as well.
You might want to repost this under for answer on Aironet products.
Community Member
Thanks Jasbryan, I will do that.
