05-12-2003 05:18 PM - edited 07-04-2021 08:42 AM
I followed the instruction to flash the formware via the console. I erased the Flash but was unable to upload the image. Now, each time I connect via the Console port, the Express Setup is no longer there. All I see is the main menu.
I could see 2 fiels: a) Config:AP Installation Key b) Config:AWC_ConfigDB
I tried uploading these file into Flash but it take forever(tried overnight) but never succeed.
Before I send in the AP for repair, is there anything I should try.
05-12-2003 07:42 PM
Unfortuantly this can only be recovered by a return to factory
07-07-2003 09:27 PM
I just had the same issue as a previous post inregards to a firmware upgrade going south on a BR-342. The flash haulted in the middle now I can not access through the console at all. Is there a boot strap inside the box that can be reset for default access?
