Community Member
350 bridge working as ap
Is the aironet 350 bridge can function as an access point with the 350 access point firmware? And what is the reverse situation ?
thx in advance anybodies response.
Community Member
Re: 350 bridge working as ap
I don't think so. They are two different products
Community Member
You can configure a 350 series bridge as an AP using the existing bridge firmware. It is one of the config options on the "Radio" settings.
An AP cannot function as a bridge.
I don't believe that you can load firmware between product sets (i.e. load bridge firmware on an AP or vice versa).
Regards, Barry
143
