Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
3850 wlc and lobby admin privileges
I've been testing a  couple of new 3850 and came across strange behavior with lobby admin configuration. With fresh config and no aaa new-model it runs as expected. Lobby admin has limited priviledges and can add/modify only guest users. But after configuring aaa new-model lobby has same privileges as any other regular user locally configured (based on privilege level). Ex. If lobby-admin is set with priv 15, he can access everything. Should lobby-admin type users be somehow configured with aaa authorization command? Could someone verify it for me?
My cfg:
aaa new-model
aaa authentication login default local
aaa authentication login webauth local
aaa authorization exec default local
aaa authorization network default local
aaa authorization network webauth local
aaa authorization credential-download default local
user-name lobby
creation-time 1373627906
privilege 15
password 0 xxxxx
type lobby-admin
Best regards,
Lukasz J.
Re: 3850 wlc and lobby admin privileges
Lukasz,
Let me check this out. What ios are you running?
Latest available:
3.2.2SE
Note that we have a bug filed for this:
CSCui383033850 5760 Lobby ambassador requires admin Priv 15 to login
Any update on this?
Any update on this?
1306
