3850 WLC mac-filter doesn't work
Make mac-filter like here: https://supportforums.cisco.com/thread/2225903
username 5ce2f4235194 mac aaa attribute list test01
wlan Guest 1 Guest
client vlan 111
no exclusionlist
mac-filtering test01
no security wpa akm dot1x
security wpa akm psk set-key ascii 0 rjekv'yrflhjdsteckeub
security wpa wpa2 ciphers tkip
session-timeout 300
no shutdown
Doesn.t work :-(
Sh term mon:
*Aug  6 23:38:02.275: %IOSXE-7-PLATFORM: 1 process wcm: 5CE2.F423.5194 AAAS: auth request sent
*Aug  6 23:38:02.280: %IOSXE-7-PLATFORM: 1 process wcm: AAAS: AAA request failed with rc 3
*Aug  6 23:38:02.280: %IOSXE-7-PLATFORM: 1 process wcm: 5CE2.F423.5194 AAAS: received response, cid=930
*Aug  6 23:38:02.280: %IOSXE-7-PLATFORM: 1 process wcm: 5CE2.F423.5194 AAAS: deleting context, cid=930
*Aug  6 23:38:02.280: %IOSXE-7-PLATFORM: 1 process wcm: AAAS: no attributes in response
*Aug  6 23:38:02.280: %IOSXE-7-PLATFORM: 1 process wcm: AAAS: aaashimAttrListToBuffer: cannot verify buffer len
*Aug  6 23:38:02.280: %IOSXE-7-PLATFORM: 1 process wcm: 5CE2.F423.5194 AAAS:  Internal Error (Failure in converting attr list to buffer).
*Aug  6 23:38:02.280: %IOSXE-7-PLATFORM: 1 process wcm: 5CE2.F423.5194 AAAS: mac filter callback status=-4 uniqueId=4889
*Aug  6 23:38:02.300: %IOSXE-7-PLATFORM: 1 process wcm: 5CE2.F423.5194 AAAS: authorization init, uid=4889, context=931
*Aug  6 23:38:02.300: %IOSXE-7-PLATFORM: 1 process wcm: 5CE2.F423.5194 AAAS: initialised auth request, id=4889
*Aug  6 23:38:02.300: %IOSXE-7-PLATFORM: 1 process wcm:   AVP type=450 len=12  : 5ce2f4235194
*Aug  6 23:38:02.300: %IOSXE-7-PLATFORM: 1 process wcm: 5CE2.F423.5194 AAAS: Submitting mac filter request for user 5ce2f4235194, uniqueId=4889 mlist=test01
*Aug  6 23:38:02.300: %IOSXE-7-PLATFORM: 1 process wcm:   AVP type=36  len=12  : 5ce2f4235194
*Aug  6 23:38:02.300: %IOSXE-7-PLATFORM: 1 process wcm:   AVP type=82  len=18  : f02929a91000:Guest
*Aug  6 23:38:02.300: %IOSXE-7-PLATFORM: 1 process wcm:   AVP type=221 len=1   : 0x30 (48) '0'
*Aug  6 23:38:02.300: %IOSXE-7-PLATFORM: 1 process wcm:   AVP type=939 len=4   : 0x00000001 (1)
*Aug  6 23:38:02.300: %IOSXE-7-PLATFORM: 1 process wcm:   AVP type=344 len=4   : 0x0000000a (10)
*Aug  6 23:38:02.300: %IOSXE-7-PLATFORM: 1 process wcm:   AVP type=112 len=4   : 0x00000514 (1300)
*Aug  6 23:38:02.300: %IOSXE-7-PLATFORM: 1 process wcm:   AVP type=225 len=4   : 0x00000013 (19)
*Aug  6 23:38:02.300: %IOSXE-7-PLATFORM: 1 process wcm:   AVP type=819 len=24  : ac1001e6520188da00001319
*Aug  6 23:38:02.300: %IOSXE-7-PLATFORM: 1 process wcm:   AVP type=448 len=4   : 0x0000000d (13)
*Aug  6 23:38:02.300: %IOSXE-7-PLATFORM: 1 process wcm:   AVP type=440 len=4   : 0x00000006 (6)
*Aug  6 23:38:02.301: %IOSXE-7-PLATFORM: 1 process wcm:   AVP type=381 len=3   : 111
I don't get any information abount these errors in internet. Can somebody help me?
SW3850#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.02.01.SE RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 20-Mar-13 17:10 by prod_rel_team
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: 3850 WLC mac-filter doesn't work
I had the same issue you have and the documentation doesn't even cover this topic, so I tried to get to the bottom of this myself.
Do a debug aaa authorization and you should see the following error:
AAA/AUTHOR (0x1A): Invalid method list id=0x0
They are caused, because the system searches for an aaa authorization list, which is not configured.
To resolve this configure the following
aaa authorization network mac-filter local
where mac-filter is the name you defined in the SSID.
Then you can define mac addresses without any delimiters as username.
username 1234567890ab mac
According to other sources metioning 3850 and mac filtering you append aaa attribute list > to the username.
I tested it successfully without this, so I wonder if this will be used in the future.
The debug should look now like this:
AAA/AUTHOR (0x22): Pick method list 'mac-filter'
And you should connect succesfully.
Patrick
By doesnt work means the wlc allows unknown mac to go through or something else?
nobody has access. Nobody go through
Hall of Fame Super Gold
Try open authentication and report back.
How? I look through manual ... for example this:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3850/software/release/3.2_0_se/security/configuration_guide/b_sec_1501_3850_cg_chapter_01110.html
But I don't have command like "authentication open" in interface context.
I do something wrong? My be you can say where get good manual?
Or full working config with mac-filter?
Can you do a show wireless summary please?
By default the 3850 is in MA mode.  If you don't have an upstream controller that is the MC/MO, then you need to tell the 3850 to be the MC
IIRC
conf t
wireless mobility controller
end
wr
reload
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
SW3850#sh run | i wireless mobility controller
So we are in MC mode
SW3850#sh wireless summary
Access Point Summary
               Total    Up    Down
802.11a/n          0     0       0
802.11b/g/n        4     4       0
All APs            4     4       0
Client Summary
Current Clients : 1
Excluded Clients: 0
Disabled Clients: 0
Patrick
Greate thanks!!!
username (mac-address) mac aaa attribute list test11
wlan 3850-01 1 3850-01
client vlan 200
mac-filtering test11
security wpa akm psk set-key ascii 0 Cisco123
no shutdown
4043
