3G Configuration On Cisco 800 Router
mibrahim81
Dear All,
could you please help me how to configure 3G on Cisco 800 routers as i didn't find any configuration guides for 800 series routers. I found for 1800 ..
6 Replies 6
Not sure which 3G you have, nor which carrier you are using (and in what country), but here's a cheat sheet for the HSPA:
http://www.davidsudjiman.info/2009/05/29/cisco-881g-and-pcex-3g-hspa-configuration-cheat-sheet/
The dial string will be different based on the carrier.
Perhaps this link from the Cisco doc might also prove useful:
http://www.cisco.com/en/US/docs/routers/access/800/860-880-890/software/configuration/guide/routconf.html#wp1147912
Dear Robert,
The country is egypt and i have two connections from two carries ( Vodafone & Etislat) .
Any way the documents you have sent is so useful . Thank you for your great support
BR,
Mohamed Ibrahim
Thank you for the rating - please let us know how it works out.
Dear Robert,
I didn't configure the router yet , i will notify you after applying it.
BR,
Mohamed Ibrahim
I have a 881 that we are configuring for proof of concept
purposes and have a question that I have been unable to
answer with online documentation and CSC.
Do I need both a Cellular interface and a Dialer interface? I have both configured the same at the moment and the router is making calls but have been told that it should work with just a Cellular interface.
The router will be making a VPN connection back to a concentrator for a site-to-site connection. Any thoughts on how to configure for a dynamic connection and not a static site-to-site VPN link?
Thanks in advance...
Brent
Some good resource information on the Cisco 800 here, including IOS upgrade and password recovery docs http://www.ciscobuy.com/cisco-routers/cisco-800
