3G-HSPA HWIC configuration - Any examples?
I Have a 1841 ISR router with a HWIC 3G-HSPA.
I configured according to Cisco doc, but I can no get the interface going up.
I don't know if there is aproblem of configuration or a ISP authentication problem
Here is my config
Building configuration...
Current configuration : 1784 bytes
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
chat-script internet "" "ATDT*98#" TIMEOUT 30 CONNECT
chat-script gsm "" "ATDT*99*#7" TIMEOUT 60 "CONNECT"
controller Cellular 0/1
interface FastEthernet0/0
ip address 10.0.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
interface Serial0/0/1
no ip address
shutdown
interface Cellular0/1/0
no ip address
ip nat outside
ip virtual-reassembly in
encapsulation ppp
load-interval 60
dialer in-band
dialer-group 1
async mode interactive
no fair-queue
interface Cellular0/1/1
no ip address
encapsulation ppp
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string gsm
dialer persistent
dialer-group 1
no fair-queue
ppp authentication chap callin
ppp chap hostname dummy
ppp chap password 0 dummy
ppp ipcp dns request
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer1
logging esm config
access-list 1 permit any
control-plane
line con 0
line aux 0
line 0/1/0
exec-timeout 0 0
script dialer gsm
login
modem InOut
no exec
transport input all
speed 237000
line 0/1/1
no exec
speed 237000
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
*********** Cellular INFO
Router#sho cellular 0/1/0 all
Hardware Information
Modem Firmware Version = K1_0_2_18AP C:/WS/F
Modem Firmware built = 12/29/08
Hardware Version = 1.0
International Mobile Subscriber Identity (IMSI) = 734021099999999
International Mobile Equipment Identity (IMEI) = 011955009999999
Integrated Circuit Card ID (ICCID) = 8958020909999999999
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) =
Factory Serial Number (FSN) = D66162036221021
Modem Status = Online
Current Modem Temperature = 37 deg C, State = Normal
PRI SKU ID = 9992680, SKU Rev. = 1.1
Profile Information
Profile 7 = INACTIVE
PDP Type = IPv4
Access Point Name (APN) = gprsweb.digitel.ve
Authentication = None
Username: , Password:
* - Default profile
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
        Inactivity Reason = Normal inactivate state
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Combined
Packet Service = EDGE (Attached)
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = VEN, Network = DIGITEL
Mobile Country Code (MCC) = 734
Mobile Network Code (MNC) = 2
Location Area Code (LAC) = 3002
Routing Area Code (RAC) = 3
Cell ID = 1851
Primary Scrambling Code = 0
PLMN Selection = Automatic
Registered PLMN =  , Abbreviated =
Service Provider =
Radio Information
Radio power mode = ON
Current Band = GSM 900, Channel Number = 104
Current RSSI = -65 dBm
Band Selected = GSM all band
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of Retries remaining = 3
Everyone's tags (2)
Silver
Re: 3G-HSPA HWIC configuration - Any examples?
Hi Esteban,
there are a couple of changes in config that may help:
- when you configure the chat-script, 99 means use the default profile (= #1) while 98 means use a specific one.
chat-script gsm "" "ATDT*99#" TIMEOUT 60 "CONNECT"  <<< use default profile
chat-script gsm "" "ATDT*98*7#" TIMEOUT 60 "CONNECT"   <<< use profile #7
- the dialer interface is configured for dialer-group 1, but you did not configure any dialer-list 1. You should add:
dialer-list 1 protocol ip list 1
- in general, you don't necessarily need a dialer interface over the cellular, as the cellular interface already behaves like a dialer. Personally I'd move all the dialer config under the cellular, and remove the dialer interface, it simplifies the troubleshooting.
Let me know if those changes help.
If not, can you capture the output of
- deb ppp nego
- deb dialer
- deb chat
Cheers
Marco
Thanks!
I'll change the config and tell you if OK
2514
