4402 - restricting concurrent logins
I see where I can restrict the number of concurrent logins a user may have in Security-->AAA-->>User Login Policies. However, this appears to be a global setting. Is there a way to set different concurrent login levels per SSID?
........thanks in advance.........J
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: 4402 - restricting concurrent logins
You can't specify concurrent login per ssid.... it is a global change.
-Scott
-Scott
If you use a radius server, you can set that.
-Scott
yes.....I suspected that RADIUS may be able to control this.....thanks for your help.....J
111
