4404 upgrade bootloader to 5.2.157
After upgrading the image on a 4404 I have downloaded the 5.2.157 bootloader as described in the release notes (http://www.cisco.com/en/US/products/ps6366/prod_release_notes_list.html) . However after downloading to the 4404, saving and rebooting a "show sysinfo" on the controller shows...
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 6.0.188.0
RTOS Version..................................... 6.0.188.0
Bootloader Version............................... 4.2.61.0
Emergency Image Version.......................... N/A
Build Type....................................... DATA + WPS
System Name...................................... xxxxxxx
System Location.................................. xxxxxxx
System Contact................................... xxxxxx
System ObjectID.................................. 1.3.6.1.4.1.14179.1.1.4.3
IP Address....................................... 10.41.0.3
System Up Time................................... 0 days 0 hrs 1 mins 39 secs
System Timezone Location......................... (GMT) London, Lisbon, Dublin, Edinburgh
Configured Country............................... GB  - United Kingdom
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +35 C
How can I get the bootloader to the correct level?
many thanks for any help,
1 ACCEPTED SOLUTION
Gold
Re: 4404 upgrade bootloader to 5.2.157
There has always been confusion on this.  The image you upgraded was not the bootloader but the Emergency Image.  The bootloader is bundled with the primary image and is upgraded if needed.  Now I see you are also running 6.0.188.0 which has a bug which is why your ER image version shows as N/A.
Gold
Thanks for the info, and the quick response. It is pretty confusing
309
