Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
4404 WLC stuck in boot loop after upgrade
In prepping for the upgrade to 4.1.185.0 I've got two controllers at different sites stuck in a boot loop after applying 4.0.219.0. Units will not even get to the <ESC> option menu.
ANy ideas?
Re: 4404 WLC stuck in boot loop after upgrade
Did you clear the configuration on the controller by using Option 5 in the boot menu? This will corrupt the boot image. You should not choose the clear config (option 5) from the boot menu on controllers running 3.2.78.0, 3.2.116.21, 3.2.150.6 or 3.2.150.10, 3.2.171.5 or 3.2.171.6, 4.0.155.5 or 4.0.179.8 and 4.0.179.11.
No, did not clear the config.
Cisco TAC has verfied the unit is now a boat anchor and has shipped a replacement. They are doing a n autopsy on theold unit to see what the problem is.
244
