4800 Access point and 350 pcimcia card
My 350 pcimcia card does not recognize my 4800 access point..my 340 card works fine.
Bronze
Re: 4800 Access point and 350 pcimcia card
You must have one of the early 4800’s. The one with the green power switch is the older model which is not entirely a 340 AP. It will work with the 340 NIC’s but not the 350’s. The 340 AP (and the 4800b model) will work with the 350 cards (with a firmware upgrade in some cases).
I have designed a WLAN w/ the AIR-AP4800-E w/ the green power switch using the Cisco 352 PC Cards and it works wonderfully.
You have to make sure the PC card is set to:
"long preamble Tx"
so it can communicate w/ the older 4800 series Access Points. The older 4800's do not support short headers.
Also, make sure you upgrade the 4800-E to the latest code 8.65 so it can support WEP at 11MB.
Mike
PS. Thanks Tom!!! :-)
177
