521 vs 11130
Can I use ap1130 radios with wlc526?.
what about to use ap521 radios with wlc2106?.
Which WLC support the new 802.11n radios?.
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: 521 vs 11130
Hi Rafael,
Sadly, the WLC 526 only supports the LAP 521. No other AP Models (like the 1131) can be used in this solution. And vice versa the 521 will not work with other WLC Models like the 2106.
Q. Which access point products are included in the Cisco Mobility Express Solution?
A. Two Cisco 500 Series Wireless Express Access Point products are in the Cisco Mobility Express Solution; their part numbers follow:
• AIR-AP521G-x-K9 (standalone access point)
• AIR-LAP521G-x-K9 (controller-based access point)
The hardware for these products is the same. The products have different software, but the access points can be converted from standalone mode to the controller-based mode with a simple software upgrade.
http://www.cisco.com/en/US/prod/collateral/wireless/ps7306/ps7319/ps7338/prod_qas0900aecd8060c860_ps7320_Products_Q_and_A_Item.html
As a core element of the Cisco Mobility Express Solution, the mobility controller is built to specifically support the Cisco 500 Series Wireless Express Access Points.
http://www.cisco.com/en/US/products/ps7320/index.html
802.11n is supported on the WLC and WCS starting with the following releases in the 4.2 train;
Release Notes for Cisco Wireless LAN Controllers and Lightweight Access Points for Release 4.2.61.0
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn4200.html#wp302677
The following new features are available in WCS 4.2.62.0
802.11n support-The introduction of the Cisco Aironet 1250 series access point, a business-class access point based on the IEEE 802.11n draft 2.0 standard. The access point offers combined data rates of up to 600 Mbps to meet bandwidth requirements. Cisco WCS display screens include a listing for configuring, managing, and monitoring 802.11n access points and their associated wireless LAN controllers.
The newest WLC and WCS 5.0 trains are now released as well :)
Hope this helps!
Rob
1 REPLY
Re: 521 vs 11130
Hi Rafael,
Hope this helps!
Rob
192
