Showing results forĀ
Search instead forĀ
Did you mean:Ā
5500 Controller/1200 Series AP Problem
joslyndm07
I am having trouble getting a 1200 series AP to join our controller. We have 1252's and 1242's sucessfully connected. We are running the latest code on the controller. The LWAP image on the AP is c1200-rcvk9w8-tar.124-21a.JA2. This is what the AP says over the console connection:
*Mar  1 00:00:06.642: %LWAPP-3-CLIENTEVENTLOG: Unable to open event log file flash:/event.log
*Mar  1 00:00:06.644: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 0 messages)
*Mar  1 00:00:07.660:  STUB Called : crypto_ssl_init
*Mar  1 00:00:08.761: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:08.798: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1200 Software (C1200-RCVK9W8-M), Version 12.4(21a)JA2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 02-Nov-09 18:06 by prod_rel_team
*Mar  1 00:00:08.835: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:09.761: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:18.133: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.1.92.26, mask 255.255.255.0, hostname AP0015.6366.e33f
Translating "CISCO-CAPWAP-CONTROLLER.2000domain.hscast.com"...domain server (192.168.128.1)
Translating "CISCO-LWAPP-CONTROLLER.2000domain.hscast.com"...domain server (192.168.128.1)
*Mar  1 00:00:38.677: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:00:38.679: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.2000domain.hscast.com
*Mar  1 00:00:38.683: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.2000domain.hscast.com
*Mar  1 00:00:48.685: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Feb 21 16:38:42.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.128.8 peer_port: 5246
*Feb 21 16:38:42.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Feb 21 16:38:43.893: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.128.8 peer_port: 5246
*Feb 21 16:38:43.895: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.128.8
*Feb 21 16:38:43.896: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Feb 21 16:38:43.905: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.128.8
*Feb 21 16:38:43.905: %DTLS-5-PEER_DISCONNECT: Peer 192.168.128.8 has closed connection.
*Feb 21 16:38:43.906: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 192.168.128.8:5246
examining image...
*Feb 21 16:38:43.907: %CAPWAP-3-ERRORLOG: Go join a lwapp controller
*Feb 21 16:38:43.907: %LWAPP-3-CLIENTERRORLOG: Set Transport AddressCalled
*Feb 21 16:36:17.690: %LWAPP-5-CHANGED: CAPWAP changed state to IMAGE
*Feb 21 16:36:20.715: %CAPWAP-3-ERRORLOG: DTLS connection not found Failed to encrypt and send packet.
*Feb 21 16:36:20.716: %CAPWAP-3-ERRORLOG: Failed to send Join request to 192.168.128.8
%Error opening lwapp:/c1200 (Incorrect Login/Password)
archive download: takes 6 seconds
*Feb 21 16:36:23.691: %LWAPP-3-CLIENTERRORLOG:  Retransmission count for type (IMAGE_DATA) exceeded more than max(1)
It repeats this over and over. I can get the controller log as well, if need be. Please help!
yeah you would have to go back to a 7.0.  I'd go with the latest 7.0 code
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
13 Replies 13
Stephen Rodriguez
What version of code are you running on the WLC?  Can you capture the following debugs concurrently?
debug mac address < ap mac>
debug capwap events
debug capwap erros
Steve
HTH,
Steve
Scott Fella
Did you add the ap 1200 mic/ssc to the 5508?
Scott Fella
Sent from my iPhone
-Scott
Here is the code we are running on the WLC: AIR-CT5500-K9-7-2-103-0. Attached is a log file from the debug commands.
ok.  7.2 does not support the 1200 AP.  1130, 1240 and anything newer.
Steve
HTH,
Steve
Ah. Ok. Thank you. Would we have to go back to an older code to support them? And if so, which version?
Steve
HTH,
Steve
Thank you very much Stephen. We will do that.
Karen Petrosyan
I have the same problem my controller runed in
7.4.110.0 (default) (active) version
debugs are attached
please suggest
Hi Karen,
Can you please create a new thread and post these details.
From WLC: sh sysinfo
From AP: sh version
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.110.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
System Name...................................... rt-wlc001
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 10.0.1.105
Last Reset....................................... Software reset
System Up Time................................... 5 days 20 hrs 58 mins 30 secs
System Timezone Location......................... (GMT +4:00) Muscat, Abu Dhabi
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... RU  - Russian Federation
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +44 C
External Temperature............................. +26 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 4
Number of Active Clients......................... 4
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ E4:C7:22:AB:12:60
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 500
AP0018.1823.cd29#sh version
ROM: Bootstrap program is C1200 boot loader
BOOTLDR: C1200 Boot Loader (C1200-BOOT-M) Version 12.3(2)JA4, RELEASE SOFTWARE (fc1)
AP0018.1823.cd29 uptime is 0 minutes
System image file is "flash:/c1200-rcvk9w8-mx.124-21a.JA2/c1200-rcvk9w8-mx.124-21a.JA"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1231G-E-K9     (PowerPC405GP) processor (revision A0) with 15038K/1336K bytes of memory.
Processor board ID FCZ1027Z2PK
PowerPC405GP CPU at 196Mhz, revision number 0x0145
Last reset from power-on
LWAPP image version 3.0.51.0
1 FastEthernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:18:18:23:CD:29
Part Number                          : 73-8704-11
PCA Assembly Number                  : 800-23211-12
PCA Revision Number                  : A0
PCB Serial Number                    : FOC102326L5
Top Assembly Part Number             : 800-23304-13
Top Assembly Serial Number           : FCZ1027Z2PK
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1231G-E-K9
Configuration register is 0xF
AP0018.1823.cd29#
HI Karen,
As per your information:
AP0018.1823.cd29#
1. 1231G AP can only support 7.0.x series and you have the higher version(7.4.100.0).
2. You have regulatery domain -E- on AP and you must use -R- Domin on AP
If you want to connect this AP to WLC then you must downgrade it.
Here is the compatibilty matrix:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Dont forget to rate helpful posts
Karen Petrosyan
Ok!!!
Thank you it's solve my problem
Dont forget to rate helpful posts, its encorages us.
