5508 WLC to Server2008 NPS Radius
choclateer
I have setup the WLC to authenticate to a MS Server2008 NPS for a WPA2/AES SSID. The connection is successful, but client authentication fails for wrong EAP-type. I believe this indicates a Windows7 client issue. Can anyone tell me the required client setup to satisfy the MS NPS?
Ok, you only want to select the EAP type as PEAP.  The inner method can be MSCHAPv2.  So remove the EAP-MSCHAPv2 from the EAP type list and try the client again.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
8 Replies 8
Stephen Rodriguez
What type of EAP are you doing on the NPS?
On the client 'smartcard/other certificate' is EAP-TLS  Protected EAP is PEAP.
Steve
HTH,
Steve
I am not using EAP/TLS I do not have a CA server.
client is set to use:
Microsoft PEAP
secured password (EAP-MS-CHAPv2)
802.1x settings = user authentication only
Mike Fleck
Datanamics, Inc
cell 702-985-5420
Just to add to Steves comments.  You need a certificate on NPS to do PEAP.  Do you have one installed.
-Scott
I checked with the server team and yes, the NPS does have a certificate.
MIke,
     Can you screen shot the NPS rules and the client setup?
Steve
HTH,
Steve
NPS properties attached
Steve
HTH,
Steve
Thanks for that. I made that change, still had a problem. A friend told me he had issues with AES, so I changed it to TKIP and it worked the first time.
