5760 Questions
Hi all, i have a few Questions about 5760 controller cause i been searching over the net and i feel like a rookie with the 5760.
Anyone have a setting up?
How can i get the UDI?
How can i upload a license via cli?
How can get access to the gui cause i can access to the first page but when i click the link to access the gui have an error.
Thank u so much everybody
Best regards!
9 Replies 9
Leo Laohoo
Hi Leo, yes i seen this before but it dosent help me so much with a problem with the gui but after i performed the upgrade to 3.3 it solved but still the question to how upload the license
Regards!!!
Hi Fernando,
See whether this helps, I hope it will
http://mrncciew.com/2013/12/12/getting-started-with-5760/
Rasika
**** Pls rate all useful responses ****
Thank u so much Rasika, after reading ur link i find another doc here on the support forums
https://supportforums.cisco.com/docs/DOC-34430
But like i say to Leo, the question about the license and how upload the license still
Regards!!!
I think it is just single command like this as described on those reference guides/links
w-5760-1#license right-to-use activate apcount slot 1 acceptEULA
Did you get a PAK for this additional licenses ? In what format you get these additional licenses
Rasika
**** Pls rate all useful resposnes ****
Hi Rasika y just apply the command that u suggest me and this what it happen, is this ok?
Regards!!
Yes, all good you have 50 permenant AP license on your 5760.
Rasika
Hope so, tomorrow im going to test it... fingers cross jajajajaja... Thanks for the help... I hope tomorrow all works fine.
best regards!!!
I hope so as well
Pls do not forget to rate our repsonses if that helps you..
Rasika
