09-20-2014 09:11 PM - edited 07-05-2021 01:34 AM
Can someone please explain to me what seeing this on WLC Config Analyzer means?
Thanks...
09-21-2014 03:01 PM
You are seeing this message (also in the log of the WLC) because the level of interference for the 2.4Ghz radio of the particular access-point is higher than the configured (or recommended) threshold.
You can find this information on the WLC on Monitor -> Access Points -> Radios -> 802.11b/g/n. You can tune those threshold on Wireless -> 802.11b/g/n -> RRM -> General.
The question for now is how high are those values and do you have problems because of this and the answer to that question is; it depends. If you think the values are too high or if you experiencing issues I would go to the location with a spectrum analyzer and see if I find the cause of the interference.
09-21-2014 04:10 PM
Just to add, questions in the config analyzer should be posted on the WLCCA forum. The owner of the tool typically will monitor.
https://supportforums.cisco.com/community/12168506/wireless-lan-controller-config-analyzer-wlcca
freerk is correct though about the thresholds defined on the WLC itself.
Scott
