Community Member
802.11a/n; High latency when Channel Bonding is turned on
AP Type       LWAPP
AP Model     AIR-LAP1252AG-A-K9
IOS Version     12.4(21a)JA2
Radio Detail :  802.11b/g/n  AIR-ANT2422DG-R
Radio Detail :  802.11a/n    AIR-ANT5140V-R
CLIENT ADAPTER
Atheros AR5009 802.11a/g/n
Version: 7.7.0.406
Settings
AP - WPA2 AES eap-fast 5.0GHz/54Mb Bonded Channels
Client - WPA2 AES eap-fast 5.0GHz/54Mb Bonded Channels
Problem:
Getting High Latency when Bonding Channels as well as packet loss.
When unbonding the channels the Latency and Packet loss is minimal.
Ping times: Bonded Channels
Minimum 1ms / Maximum 2765ms / Average 189ms
Packets lost out of 1000 = 509
Ping Times: Unbonded Channels
Minimum 1ms / Maximum 115ms / Average 3ms
Packet's lost out of 1000 = 3
Why do we care? I want to use Bonded Channels to increase throughput.
These Clients are viewing large image files and they need to load quickly.
Thanks for your assistance!
~Michael
Hall of Fame Super Blue
Re: 802.11a/n; High latency when Channel Bonding is turned on
From the main page, if you click on "Clients" and the client's MAC address, what is the Signal Strength and the Noise level?
Community Member
is this what you're asking for? Also the AP is located within 30 feet away at the most.
Client RSSI is -81dB
Client SNR is 17
i've opened a TAC case. I'm about to deploy 140 devices and I need this working
ASAP. So in the interest of time... I'll post the results of our disgnostics with TAC once this
is complete. Thanks gang!
~Michael
You got this right Michael and the result is not good.  -81dBm Signal Strength and 17 SNR is not a good sign.  It sounds like the client is too far away from the AP or there could be obstacles blocking between the AP and the client.  A good Signal Strength is -65 dBm or lower is better and 25 dBm or higher is better for the SNR.  I could be wrong.
1410
