09-29-2009 12:39 PM - edited 07-03-2021 06:05 PM
Code version is 5.2.193. I converted some 1130 series access points to LWAPP. All of the newer access points worked fine, but the A radios in the older access points are not coming up. I assume there was a hardware change someplace along the line. If I try to manually disable the interface I get the following error:
Failed to Set Admin Status of AP
Error in Setting Antenna TypeError in Setting Antenna Diversity
The b/g radios work fine. Has anyone seen this?
Solved! Go to Solution.
09-29-2009 02:58 PM
What is the exact model of your AP? Could be the domain does not match the country you are in.
09-29-2009 02:58 PM
09-29-2009 03:51 PM
You are correct. Somehow we ended up with some -N-'s. Got any -A-'s you want to trade!
09-29-2009 04:57 PM
Thanks for the rating.
As a matter of fact, I have a number of "-A" (1240) that our supplier sold us by mistake and we suppose to use "-N".
09-29-2009 04:59 PM
LOL!!!
These are 4 year old 1131s. We never noticed until the controller install.
