802.11ac client card
Hi Community
We're in a process of testing 802.11ac access point in a live environment, that said covering an entire floor of a building and wireless for all users instead of cabling. There is a mix of laptop and desktop; The choice of the AP is already done, we'll use 3700 AP. But actually we do not know what model of client's card we'll use for the lab. We need a card which must support 802.11 ac and if possible 3SS.
Do you have any recommendation regarding the best choice for our clients?
Many thanks!
Théo
Everyone's tags (1)
VIP Purple
HI,I dont know if it is the
HI,
I dont know if it is the right answer or not.
please check this:
https://wikidevi.com/wiki/List_of_802.11ac_Hardware
dont forget to rate helpful posts
Hi, thanks for your answer. I
Hi, thanks for your answer. I'll have a look at your doc. Following this doc, are they client card more appreciated than other?
Best regards
Seems that manufacturer
Seems that manufacturer cannot provide wireless adapter supporting 3x3:3 with an usb3 connection? I can see many adapters with Pci-e or mini pci-e. Is it relative to the connection speed?
Hi Theo ,you can test with
Hi Theo ,
you can test with Apple MAC air or MAC pro . i think those supporting 3SS
Fouad
111
