Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
802.11b adaptor and AP1231G
I bought 2 AP1231G (802.11g) last week. And I tried to install them in our office
When I use my notebook with 802.11g Wireless adaptor , the connection between AP1231G and my notebook is normal
But when I use 802.11b Wireless adaptor , the AP1231G can't defect the 802.11b adaptor exist.
Is it any problem in my configuration which is shown below
Thank for your help
AP config:
Current configuration : 2490 bytes
version 12.2
no service pad
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname AP
enable secret xxxx
ip subnet-zero
ip domain name office
ip name-server 120.99.170.32
ip name-server 120.99.170.33
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 network-map
dot11 arp-cache
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 40bit 7 93797EB19A0B transmit-key
encryption mode ciphers wep40
ssid office
authentication open mac-address mac_methods
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
rts threshold 2312
station-role root
no dot11 extension aironet
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 120.99.170.50 255.255.255.0
no ip route-cache
ip default-gateway 120.99.170.2
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
/ivory/1100
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server authorization permit missing Service-Type
radius-server vsa send accounting
bridge 1 route ip
wlccp ap username root password xxxx
line con 0
line vty 5 15
end
Re: 802.11b adaptor and AP1231G
I was having a similar problem today: my Cisco 802.11a CA worked fine to the AP doing local LEAP authentication (local AP is radius server), but I could not get an 802.11b CA connecting to the 802.11G mini-PCI card (AIR-MP21G-E-K9) on the 1200 using the same authentication config.
I did, however, work out the answer to the problem...If you use an 802.11b CA to an 802.11g radio module, you need to set the interface Dot11Radio0 to the 802.11b speeds ONLY. i.e you need to set the speed command to the following:
speed basic-1.0 2.0 5.5 11.0
(The higher 802.11g speeds will be excluded). Once this is done, your 802.11b client should work to the 802.11g card on the 1200. It did for me.
This is partially incorrect...
The 802.11g upgrade kit for both the 1200\1100 series AP's will operate it "mixed" mode...
The following speed setting on int d0 (which is actually the default) allows both 802.11b & 802.11g clients to associate, albeit the 802.11g client throughput will "suck" badly
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
Dave S.
It looks like your using mac-address filters but have not defined any "allowed" clients
Thx reply
I am sure that I put the 802.11b Adaptor in the allow list
did you modify your speed settings for int dot0? By default, they will require 11mb for 802.11b devices, and your CA device may not be able to attain that rate? whether it is due to distance, interference or any other variable that could choke the connection rate
186
