802.11b/g/n Operational Status down for Mesh AP 1522E
We have Outdoor Mesh Deployment , where we have configure RAP , MAP ..
We are facing problem that our 802.11b/g/n is shownig operational down ( but Admin Status is enable) ..
Our 802.11a/n is operational & admin status are up ...
As highlighted above , only 802.11n supported devices are able to connect and 802.11b/g are not able to connect
Can anyone suggest the fix up to make 802.11b/g/n operational status up.
We have WLC5508 with 7.0.xx OS
Everyone's tags (2)
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
What is the complete output to the command "sh sysinfo"?  Post both pages of the command.
Hall of Fame Super Silver
Well.... we would like to make sure everything is correct... the show sysinfo is information for us to know for sure.  From what you posted, I would guess it would work...
It would also help to post your show run-config and tell us what AP's to look at.  Might be a configuration issue also.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Re: 802.11b/g/n Operational Status down for Mesh AP 1522E
Is this an issue with all your raps and maps? You have the correct country domain listed in the WLC?
-Scott
Thanks Scott
Please find the details requested by you
Yes this Issue is with every RAP & MAP ..
Outdoor Access Points is AIR-CAP1552E-N-K9 ( 2.4 GHz 4dBi / 5 GHz 7dBi Dual Band Omni Antenne , N Connector)
WLC is  CT-5508-250-K9
Country Code is IN ( India) configured on WLC...
Please suggest
Hi Scott / Leo
Can u suggest recommendation base on provided info
Scott
-Scott
Hi Scott
Please find the details show sysinfo attached ...
FYI again
as highlighted above , only 802.11n supported devices are able to connect and 802.11b/g are not able to connect
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.10.05 12:44:29 =~=~=~=~=~=~=~=~=~=~=~=
(Cisco Controller) >show sy?
sysinfo        syslog
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.220.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS + LDPE
System Name...................................... GNDEC-WLC01
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
IP Address....................................... 10.10.9.2
Last Reset....................................... Power on reset
System Up Time................................... 0 days 3 hrs 34 mins 19 secs
System Timezone Location.........................
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
--More-- or (q)uit
Configured Country............................... IN  - India
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +40 C
External Temperature............................. +20 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 1
Burned-in MAC Address............................ F0:F7:55:2B:7C:20
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 250
806
