802.11b to 802.11a upgrade
Can the Cisco Aeronet 340 Access Point using the 802.11b protocol be upgraded to 802.11a via some type of firmware or any other upgrade?
thanks
hpfeil
1 REPLY
Re: 802.11b to 802.11a upgrade
They use different frequencies, so there is no direct upgrade path.
Even if you open the AP and replaced the PCMCIA card you will not get 802.11a (.11a cards are CardBus and all of the parameters are different, plus the only shipping products use the Atheros chipset, which the Aironet APs were never designed to talk to.)
The only currently shipping APs that promise an upgrade path are those that use an external slot (you can see the PCMCIA card sticking out) and I don't think that their upgrade is shipping - just the press release.
264
