802.11b usb adapter which supports peap?
anybody knows a 802.11b USB (!) adapter which support PEAP authentication?
Alex
Bronze
Re: 802.11b usb adapter which supports peap?
I think Cisco Aironet 350 Series Client Adapters supports PEAP. Check out the following URL for more details.
http://www.cisco.com/en/US/partner/products/hw/wireless/ps4555/products_data_sheet09186a0080088828.html
yes Cisco supports PEAP, But I don't think Cisco has a USB 802.11b radio.
If they do and you find one then your in luck, (As long as it is newer,( 350, or 340 series)).
You may want to look at Linksys products (Which happens to be a division of Cisco) they may have a PEAP USB 802.11b Client Adapter.
We ahve already tried linksys also doesnt work under windows 2k, under xp it worked!
bernhard
Hm... usb network adapter with PEAP.
If you say it worked with XP and not with win2k, make sure your win2k install is at SP3 with the 802.1x client (loaded in addition to sp3). SP4 does also have the client, but your organization may not like running sp4 (due to apps breaking, etc)
333
