802.11n and Cisco wireless APs
We're planning on installing a wireless network using Cisco Aironet 1130AG series radios. Does anyone know if these wireless APs are upgradable to the 802.11n standard later on?
1 REPLY
Bronze
Re: 802.11n and Cisco wireless APs
Personnaly I'dont believe cisco is going to make them upgradeble:
802.11n uses diffrent radio techniques so if they would become upgradeble you will need to replace the radio.
The FastEthernet Port will not be fast enough and will become the bottleneck of the box (you have to know that 802.11n will try to do +100Mbps net)
Hope this helped you a bit
121
