Bronze
802.11n greenfield in a mixed environment
we plan to have mixed 802.11n deployment coexistence with a/b/g clients. But we want to have some classrooms or labs to run greenfield only where people request 100Mbps bandwidth to transfer large images. What is the best practice to design some small greenfield areas in the mixed environment? And what is the best way to prevent 802.11a users to associate to our 1140s?
Thanks!
Zhenning
  • Other Wireless - Mobility Subjects
Re: 802.11n greenfield in a mixed environment
I can't speak to the interoperability issues, but it seems logical that you can keep 802.11a (and b/g) users off your 802.11n AP's by simply disabling the speeds they can use. The beacon frames will then not list these speeds as being supported, therefore the clients should not attempt to join.
Do you have, or will you have, 802.11a support in some areas? Is it possible you could support 802.11b/g for your legacy clients, and only enable 802.11n for the 5GHz frequencies (and provide no support at all for 802.11a)?
Bronze
Thank you for the reply. It seems I can't disable all the 802.11a speed(at least one has to be enabled). So I have to leave at least 54Mbps?
In our current wireless network, we support all a/b/g clients and we don't want to change that. I am thinking to add one more WLC for greenfield only. We will only add the new 1142 APs to that WLC and do not support 802.11a on that WLC. Are there any better ways to do this?
Silver
Additionally, aren't the data rates a global setting? So even if you could disable all rates 54Mbps and under, you wouldn't be able to use 802.11a anywhere, and you're looking to simply devote certain APs to 802.11n.
I honestly don't know how you might accomplish this. I don't have enough experience with 802.11n. Hopefully someone else here does :D
Bronze
Yes the data rates are global settings. So I am thinking to use a dedicated WLC for greenfield APs. I don't want 802.11a users to associate to those small number of APs using non-broadcast SSIDs. I know it is not ideal. But I cannot get any better ideas. :(
Hall of Fame Super Gold
Try AP Group.
Bronze
still cannot get how AP Group can help... Can you set different radio policies to different AP groups?
Bronze
No. From my knowledge, AP Group cannot solve my issue at all. Can you be more specific how AP Group can help on my issue? Thanks.
What controller version are you running? We are running 5.2.178.0 and I am using AP groups and different WLANS to achieve exactly what you are asking. What I did was create a SSID for N only, call it N_Test for example. Also make sure you have WMM and AES encryption on the new SSID. Then create an AP group with only the APs you want the N clients in, assign the new N_Test SSID to that group.
Doing this should help you achieve what you are trying. Only give your N clients the key or access to the N_Test SSID, which would then keep your A clients off.
1677
