802.11n on 1252
I can't get this to work at 300Mbps.  Highest it goes is 72Mbps.  I've searched to no end.  Here's my config.  What is wrong?  If anyone could tell me what exactly needs to be changed, as in what commands to issue, I'd really appreciate it.
version 12.4
no service pad
service password-encryption
hostname IT_WAP
enable secret 5 xxxxxx
no aaa new-model
dot11 ssid myssid
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 xxxxxxxxxxx
power inline negotiation prestandard source
username Cisco password 7 xxxxxxxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid myssid
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
ssid myssid
dfs band 3 block
speed  basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.1.215 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.254
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Everyone's tags (2)
Hall of Fame Super Silver
802.11n on 1252
You will only achieve up to 300mbps on the 5ghz not the 2.4ghz.  on the 5ghz radio, you need to configure that for 40 mhz channel width.
-Scott
802.11n on 1252
Ok.  I changed the channel width to above 40 mhz.  This gets me to 150 Mbps.  Anything else to try?  Is the encryption mode correct?
no ip address
no ip route-cache
ssid myssid
dfs band 3 block
channel width 40-above
channel dfs
station-role root
bridge-group 1
end
802.11n on 1252
how many antenna do you have the radio?  you should have three per radio.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
802.11n on 1252
Correct.  3 antenna per radio.  I read something about channel bonding, but do not know the command or gui steps to do that.
Hall of Fame Super Gold
Re: 802.11n on 1252
How are you powering up the WAP?  If it's via PoE then what exact switch model or what power is the WAP drawing?
Can you describe what client are you using?  Can you specify the exact model of the wireless NIC you are using?
Re: 802.11n on 1252
Hood that helps. What are the client specs? If they are a single spatial stream your doing good. If dual or triple....
Steve
898
