Community Member
802.1Q
On a Aironet 350 non-root bridge is it possible to disable 801.1q bridging on the Ethernet port only? ie leave it on the Radio side side only
1 REPLY
Bronze
Re: 802.1Q
If there are no VLANs setup on the bridge, 802.1q will be disabled by default. The only way to enable 802.1q is to configure a VLAN. The following doc should help out.
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/350brdgs/brscg/index.htm
130
