857W Connect Can't browse on wireless
This is my Problem, I connect to the Wireless portion (with WPA) but i can not browse the Internet but can SSH to the router with out a problem, If i connect via Ethernet i do not have an issue browsing at all.
Building configuration...
Current configuration : 6850 bytes
version 12.4
no service pad
hostname 857W
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
clock timezone NewYork -5
clock summer-time NewYork date Apr 6 2003 2:00 Oct 26 2003 2:00
no ip dhcp use vrf connected
ip dhcp pool sdm-pool
   import all
   network 10.10.10.0 255.255.255.224
   default-router 10.10.10.1
   domain-name ninja.ca
   dns-server 4.2.2.2 4.2.2.3
   lease 0 2
ip cef
ip domain lookup source-interface Dialer0
ip domain name idsg.ca
ip name-server 4.2.2.2
ip name-server 4.2.2.3
ip ddns update method sdm_ddns1
HTTP
ip ddns update method sdm_ddns2
HTTP
crypto pki trustpoint TP-self-signed-3071840133
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3071840133
revocation-check none
rsakeypair TP-self-signed-3071840133
crypto pki certificate chain TP-self-signed-3071840133
certificate self-signed 01
  quit
username xxxxxx privilege 15 secret 5 $1$vVL1$0IebqxFuI81uvF0PwliF60
username xxxxxxx privilege 15 secret 5 $1$06HG$nXZXFS0.DJ74qW/lpIU.11
crypto isakmp policy 100
encr aes
authentication pre-share
group 2
crypto isakmp key xxxxxxxxx address 10.10.10.20
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to10.10.10.20
set peer 10.10.10.20
set transform-set ESP-3DES-SHA
match address 100
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no snmp trap link-status
pvc 0/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption mode ciphers tkip
ssid X-R0320CW
    authentication open
    authentication key-management wpa
    guest-mode
    infrastructure-ssid optional
    wpa-psk ascii 0 xxxxxxxxxx
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
no ip address
ip tcp adjust-mss 1452
shutdown
bridge-group 1
bridge-group 1 spanning-disabled
interface Dialer0
bandwidth 16000
ip ddns update hostname xxxxxxxx
ip ddns update sdm_ddns2
ip address negotiated
no ip redirects
no ip unreachables
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxxxxx
ppp chap password 0 xxxxxx
ppp pap sent-username xxxx password 0 xxxxxx
ppp ipcp dns request
ppp ipcp route default
interface BVI1
bandwidth 160000
ip address 10.10.10.1 255.255.255.224
ip nat inside
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip dns server
logging 10.0.0.2
access-list 100 remark CCP_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip 10.10.10.0 0.0.0.255 host 10.10.10.20
no cdp run
control-plane
bridge 1 route ip
banner login ^C
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
Re: 857W Connect Can't browse on wireless
i request you to check out the below link.. which will provide us the simple configuration example to get the wireless network up and running on the 871.. its the same on 857 as well i guess
https://supportforums.cisco.com/docs/DOC-13603
let me know how this works out for you!!
Surendra
When connected via wireless, are you able to ping the internet (4.2.2.2) and the default gateway 10.10.10.1?
Instead of typing the name of the site like yahoo.com, can you try entering the ip address of the site in the address bar and let me know it works?
Maithri
I see that you overloading using ACL 1 from config.
However I do not see any ACL 1.
Make the followign 2 changes and verfiy if it would then work:
conf t
   access-list 1 permit 10.10.10.0 0.0.0.255
   bridge 1 protocol ieee
Madhuri
Hi All,
Thank yo for your Answers,i have not tried any of them yet as i had been studying for the CCNa security i will try what u have siggested tonight and get back to u ..
Again thank you for answering.
Pat
676
