Community Member
881W Integrated AP
I am having an issue with an 881W router with the integrated AP. Our campus is using 1310 bridges to connect a remote apartment that houses students. Within that apartment we have a 881W router and are using the integrated AP. We have the advancedipservices license and I have configured the router so that the ap boots in unified mode so that it can act as a lwapp and join our 4400 controller on campus. I was able to get the ap to join the controller and function properly but ocassionally it will reboot and end up at the "Would you like to enter the initial configuration dialog" prompt.
This is the logging from the last time it rebooted:
%LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct 21 22:44:06.751: WARNING: invalid REAP slot ID (255) for msg type 7
%LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
%WIDS-6-ENABLED: IDS Signature is loaded and enabled
%LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
%LWAPP-3-CLIENTERRORLOG: Retransmission count for packet exceeded max(ECHO_REQUE
ST
, 2)
%LWAPP-3-CLIENTERRORLOG: GOING BACK TO DISCOVER MODE
%WIDS-6-DISABLED: IDS Signature is removed and disabled.
%LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
%LWAPP-5-CHANGED: LWAPP changed state to JOIN
%LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
%LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to do
wn
%LWAPP-3-CLIENTERRORLOG: Join Timer: did not recieve join response (controller -
WLC_WLC-2)
%LWAPP-3-CLIENTERRORLOG: Set Transport Address: no more AP manager IP addresses
remain
Writing out the event log to nvram...
1)
remain
%SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET JOIN
RESPONSE.
%LWAPP-5-CHANGED: LWAPP changed state to DOWN
IOS Bootloader - Starting system.
Xmodem file system is available.
Bringing up flash file system:
flashfs[0]: 155 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31481856
flashfs[0]: Bytes used: 13186560
flashfs[0]: Bytes available: 18295296
flashfs[0]: flashfs fsck took 13 seconds.
Reading cookie from flash parameter block...done.
There are also times where I will see the following messages repeatedly until the ap reboots itself.
%LWAPP-3-CLIENTERRORLOG: Decode Msg: could not match WLAN ID 3
%LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
Usually if I answer no at the initial config dialog prompt and reload the ap it will reboot and rejoin the controller for awhile and then start the process all over again.
Any ideas as to what would be causing this to happen?
Thanks in advance.
Jeff
1 REPLY
Hall of Fame Super Gold
Re: 881W Integrated AP
"could not match WLAN ID 3"
Can you check the router's VLAN tagging information?
622
