Community Member
900Mhz Arlan channel allocation
hi
i started to support an old (1998) arlan 630-900 installation (warehouse).
there are 7 APs covering the warehouse, all set to the same channel (ch1, 910mhz) - is this correct?
with 802.11b/g equipment i would set the APs to different channels 1,6,11 to avoid interferences - isn't this a problem with the arlan 900mhz technology?
there are currently connectivity problems from the barcode readers...could this be the reason?
thx
michael
1 REPLY
Community Member
Re: 900Mhz Arlan channel allocation
hi h r u
153
