Community Member
ACCESS POINT 1300 intermitent fails
i got two Access point 1300, 1 like root and another like non-root, the bug is the next ( no parent longer valid deauthentication client xxxx.xxxx.xxxx) and the devices lost the connection every 10 min aprox... any comments about is really helpfully all the informations that you can supply for me.
1 REPLY
Silver
Re: ACCESS POINT 1300 intermitent fails
If there is a mismatch in the authentication parameters on the AP and the client, the authentication fails. Check if the authentication parameters are configured correctly on the AP and the client.
Antenna alignment directly relates to the proper LoS between the two bridges. If the antenna is not properly aligned, the RF signals cannot reach the endpoints and authentication fails. Always ensure that the antennas are properly aligned.
123
