Access point 3502i not joining the Virtual wireless controller
g_parmar83
i try to install the two 3502i access points to the virtual wireless controller
but unable to join them to controller.
the lightwieght image running on 3502i is
" ap3g1-rcvk9w8-tar.124-23c.JA2.tar "
need help
and getting error
*Jul  4 13:16:39.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.30.100.200 peer_port: 5246
*Jul  4 13:16:39.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul  4 13:16:39.015: %LWAPP-3-CLIENTERRORLOG: Peer certificate verification failed
*Jul  4 13:16:39.015: %CAPWAP-3-ERRORLOG: Certificate verification failed!
*Jul  4 13:16:39.015: DTLS_CLIENT_ERROR: ../capwap/capwap_wtp_dtls.c:348 Certificate verified failed!
*Jul  4 13:16:39.015: %DTLS-4-BAD_CERT: Certificate verification failed. Peer IP: 172.30.100.200
*Jul  4 13:16:39.015: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 172.30.100.200:5246
*Jul  4 13:16:39.015: %DTLS-3-BAD_RECORD: Erroneous record received from 172.30.100.200: Malformed Certificate
*Jul  4 13:16:39.015: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.30.100.200:5246
*Jul  4 13:16:39.015: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination.
*Jul  4 13:17:44.103: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Jul  4 13:17:44.166: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jul  4 13:17:44.166: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jul  4 13:17:44.176: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jul  4 13:17:44.185:  status of voice_diag_test from WLC is false
*Jul  4 13:17:44.185: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Jul  4 13:17:44.195: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jul  4 13:17:44.204: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jul  4 13:17:44.220: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Jul  4 13:17:54.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.30.100.200 peer_port: 5246
*Jul  4 13:17:54.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jul  4 13:17:54.015: %LWAPP-3-CLIENTERRORLOG: Peer certificate verification failed
*Jul  4 13:17:54.015: %CAPWAP-3-ERRORLOG: Certificate verification failed!
*Jul  4 13:17:54.015: DTLS_CLIENT_ERROR: ../capwap/capwap_wtp_dtls.c:348 Certificate verified failed!
*Jul  4 13:17:54.015: %DTLS-4-BAD_CERT: Certificate verification failed. Peer IP: 172.30.100.200
*Jul  4 13:17:54.015: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 172.30.100.200:5246
*Jul  4 13:17:54.015: %DTLS-3-BAD_RECORD: Erroneous record received from 172.30.100.200: Malformed Certificate
*Jul  4 13:17:54.015: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.30.100.200:5246
*Jul  4 13:17:54.015: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination.
the time is set properly on the WLC
thanks in advance
2 Accepted Solutions
Scott Fella
Try this software: ap3g1-rcvk9w8-tar.152-2.JB.tar
With the code you have on the 3502i, you would need to join that AP to a WLC that is running v7.3 or later before you can have it join the vWLC.
http://www.cisco.com/en/US/products/ps12723/products_tech_note09186a0080bd2d04.shtml#hash
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Scott Fella
If that doesn't work, then boot the AP in ROMMON and upload the code that way.
-Scott
16 Replies 16
Scott Fella
Scott
-Scott
thanks scott for your quick reply, i will try the new software that you mentioned and the WLC is running on 7.3
The vWLC can be running either on v7.3 or v7.4.  Just read the link that I posted as you might also have to disable the hash.
Scott
-Scott
Need help again
unable to upload the new image on 3502i because there is no archive command available and
it is not joining the virtual Wireless LAN controller.
thanks in adavnce
Use the debug capwap console cli
Don't do a ? As it will not show up. Just issue the command from the cli. Then you can do the archive.
-Scott
i follow your steps
first i issue the "debug capwap console cli"
and then issue the followong command
archive download-sw/overwrite tftp://172.30.100.46/name of file
and get invalid input detected at archive
thanks again
Can you post the error.
-Scott
first of all i gonna thanks for keep replying to my posts
here is command and error:
and it is exact samething i copied from the securecrt
archive dowload-sw/overwrite tftp://172.30.100.46/ap3g1-rcvk9w8-tar.152-2.JB.tar
% Invalid input detected at '^' marker.
thanks
Well after you did the debug capwap console cli, can you issue a config t?
-Scott
yes i can issue the conf t and right now i am in Configure mode
Okay well then you are in the debug successfully. The archive command isn't run from the configuration mode but should be allowed in the global mode.
-Scott
What????
The command "debug capwap console cli" is invalid in configuration mode.  It has to be entered in ENABLE mode.
Please try again.
Thanks everyone for help
Like scott said as soon as i update the firmware with the latest one the access points joins the Virtual controller
and now my Wireless network working very well
Thanks again
Scott Fella
-Scott
