05-18-2012 05:54 AM - edited 07-03-2021 10:11 PM
Hi everyone,
I have 17 units of Access Points(AIR-AP1041N-E-K9) and a Wireless LAN Controller(AIR-WLC2125-k9).
I know that these access point are standalone, but can this controller be used with these access point?
If not what can be done to make the controller control all these access point?
please advice?
br
adeola
05-18-2012 06:00 AM
The WLC can work with the WAPs you've mentioned as long as the WAPs are running the correct IOS and the WLC is running 7.X firmware.
To convert the WAPs from autonomous to CAPWAP/LWAP is as simple as copying the lightweight IOS and booting from it.
05-18-2012 06:56 AM
the IOS in the WAP is below:
S104W7K9-12425JA | Cisco 1040 Series IOS WIRELESS LAN |
br
adeola
05-18-2012 07:03 AM
That's the wrong software. You need LIGHTWEIGHT IOS.
05-21-2012 08:00 AM
So what are the procedure that I will use to convert the AP to LAP?
br
05-21-2012 03:34 PM
To convert the WAPs from autonomous to CAPWAP/LWAP is as simple as copying the lightweight IOS into the WAP and booting from it.
05-22-2012 11:25 PM
have the LWAPP/CAPWAP recovery image on your tftp server.
The image name should have something like k9w8
on the AP run the following command:
AP#archive download-sw /overwrite /reload tftp://......................
Please make sure to rate correct answers
05-22-2012 09:31 PM
To convert the unit fro
IOS to LWAPP you just need to download the LWAPP image to a tftp server and then use the normal ios upgrade procedure with the archive command using the lwapp image instead of the IOS and once the ap reboots it will be in lwapp mode.
06-16-2013 04:18 PM
Please find the upgradation guide, It may help you in this:
