Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Access Point support 802.11a/g/b/r
can you suggest me the access point which support 802.11a/g/b/r ?
My problem is with 802.11 r. i am not getting clear idea about the wireless access point which will support 802.11r
kindly suggest me the product
1 REPLY
Bronze
Re: Access Point support 802.11a/g/b/r
There are no APs that support 802.11r yet. 802.11r is a standards extension to support fast secure roaming that was only ratified a month or so ago. It requires client device support and there are no clients that support it yet.
If you want fast secure roaming, Cisco offers CCKM on all our APs and CCKM and PKC on all our controllers.
I suspect though, that you may have meant, 802.11n, which is a higher data rate PHY/MAC standards extension. That is supported in the AP1250 series.
574
