ACU v6.1 splash screen problem
Does anyone know why when you log in to your device when you are using the new ACU it takes about 60-70 seconds for the splash screen that says "starting LEAP-> Checking Link Status-> Renewing IP add-> Finding Domain Controller" to go away? It seems to get stuck on Finding domain controller. Is there a timeout value that you can change? Any help will be appreciated
1 REPLY
Silver
Re: ACU v6.1 splash screen problem
I think you are running into the bug CSCea17024.
112
