Added IOS AP1200 into larege deployment of VxWorks
I added an AP1200 with IOS on the same network as 120 other Cisco APs using VxWorks and I noticed the network map from the APs running VxWorks did not show the new IOS based AP. All APs are working fine even the IOS model. Is there a problem with the mixed assortment of IOS and VxWorks APs ?
Thanks.
Greg
Silver
Re: Added IOS AP1200 into larege deployment of VxWorks
What VX version are you running, I did an update to firmware 12.03T, it solved my problem.
I am running 12.02T1.
Thanks.
Greg
99
