Community Member
AES-CCMP TSC replay was detected
Hi NetPro,
anyone know what is that mean ?
AES-CCMP TSC replay was detected on a packet (TSC 0x1C07) received from 001b.7709.0301.
your reply will be highly appreciated.
Jackal
Re: AES-CCMP TSC replay was detected
Hi Jackal,
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_8_JA/configuration/guide/s38err.html
Error Message: DOT11-4-CCMP_REPLAY: "AES-CCMP TSC replay was detected on packet (TSC
0x%11x received from &e)."
Explanation: AES-CCMP TSC replay was indicated on a frame. A replay of the AES-CCMP TSC in a received packet almost indicates an active attack.
Recommended Action: None.
HTH,
-J
Community Member
Hi J
thanks for reply, yes i have checked cisco site as well, your msg basically was same to Cisco. i feel something is not right, coz i noticed wlan connection affected and some more if no action taken, then what does this msg stand for ? if just information only why Cisco need to advertise the logs on the device ? it maybe client software problem or cisco device problem ? ... hmn.....
anyway, thanks for ur update.
thanks.
Jackal
5400
