After "Clear stats on all AP" joined APs are not appearing
vinod rathore
Few days back i edited access-points name and saved configuration.
After that when i look at Monitor>Statistics>AP join
Few of APs name are not correct they are still appearing with old name where under wireless > All APs
showing all name correctly.
I tried  Monitor>Statistics>AP join> clear stats on all APs
thereafter all APs gone form the list and still not visible however those APs are running fine and no issue at all but why they're not appearing back there ?
Sandeep Choudhary
HI Vinod,
Monitor>Statistics>AP Join
Here you will just see the summary of all access points that joined or attempted to join to the controller.
Once you clear this you will not having any stat about earlier joined attemps.
If any later new AP will try to join then only you can see the new stats here.
Hope it helps.
Dont forget to rate helpful posts
Sandeep Choudhary
HI Vinod,
Hope it helps.
