AIR-702W - Configure Local LAN ports from WLC 5760
hello,
was hoping someone might be able to assist with the following:  i am trying to configure local LAN ports on my 702w AP's for access mode and vlan from AIR-5760 CLI.  can find good examples of how to do this in Air-OS, but not in IOS-XE.  i managed to get the LAN ports enabled as follows, but cannot work out how to configure mode/vlans - "shutdown" appears to be the only command/syntax option available:
 wc5760-02#ap name AP0008.2f1c.0628 no lan port-id 1 shutdown
wc5760-02#sho ap name AP0008.2f1c.0628 lan port summ
LAN Port status for AP AP0008.2f1c.0628
Port ID  Status
LAN1     Enabled
LAN2     Disabled
LAN3     Disabled
LAN4     Disabled
wc5760-02#ap name AP0008.2f1c.0628 lan port 1 ?
  shutdown  Disable the Port
does anyone know how to configure local LAN ports from here in IOS-XE?  my AIR-CT5760 SW ver = 03.06.00E;  my 702w SW ver =  10.2.102.0
thank you for your assistance...
gt
Configuring VLANs on AP
Configuring VLANs on AP 702W
From code release 8.0.75.1 onward, you can configure LAN ports and VLAN assignments.
Before setting VLANs, enable the LED state on the 702W AP, so you can confirm whether the client is connected because the ports and LEDs are in disabled state by default.
To enable the LED state from the CLI, use the command: config ap led-state enable
 i believe code release
i believe code release mentioned above refers to Airespace Operating System?  we have 5760's running IOS-XE.  while i am able to find configuration examples of 702w VLAN tagging on platforms running Airespace OS, i can find nothing re: 702w local LAN VLAN tagging configuration from IOS-XE 03.06.00E.
VIP Purple
Hi I do not think IOS-XE 3.6
I do not think IOS-XE 3.6 supports vlan tagging of this 702W AP model. May be in upcoming releases they may support this.
Rasika
***Pls rate all useful responses ****
543
