AIR-ANT2506 ... Can it be mounted up-side-down?
Just wondering if I'd lose any signal strength if I was to mount the AIR-ANT2506 in the up-side-down position.
The reason I want to do this is that currently we have an AIR-ANT2506 mounted to the side of an outdoor enclosure, where it sits raised above the enclosure. But I feel that the enclosure is mounted a bit too high, so I thought about mounting the antenna in the 'hanging' position from the enclosure to lower the position of the antenna.
Can the AIR-ANT2506 be mounted in this way without any consequence?
Hall of Fame Super Red
Re: AIR-ANT2506 ... Can it be mounted up-side-down?
Hi David,
The 2506 can be mounted in an inverted position but you do run the risk of it filling up with water if exposed to moisture;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cbfde67
Hope this helps!
Rob
Thanks Rob,
I think I'll try getting the AP enclosure lowered rather than mount the antenna inverted.
210
