AIR-AP1042N-N-K9 Issue
I'm hoping someone can help me figure out what's going on with the Cisco AIR-AP1042N-N-K9 I've been trying to deploy.
It's a pretty simple setup on the clients site. There's a Cisco 887, a couple of PC and the AP1024 that's giving me issues. Out of the 80 odd sites we support with this setup, this is the only AP1024 I'm having issues with.
I use a standard config (and it's worked on the other APs) and only change the IP address and user credentials on it. I connect via console, copy the config, save it and do a quick test that I can connect to the SSID - it looks all good.
When it was deployed to the site, they were having issues connecting to it, so I jumped onto the 887, then connected to the AP. I was able to log on, and enter priviledged exec mode, but when I did a show run, the AP froze for a few minutes, then kicked me off.
I could connect to the AP again, but everytime I tried to do anything that really required an output from the AP, it kept freezing.
A restart didn't resolve the issue.
The AP was returned to me and I conencted to it via the console again, and it worked fine. I didn't have any issues any commands.
I decided to replicate the environment, and connect to the AP through the router, and it froze again.
I'm kinda at a loss as to what the issue is. I did try to set the speed and duplex on the ports to match incase that was the issue, but it's still occuring.
The config is below:
no service pad
service password-encryption
hostname <APname>
logging rate-limit console 9
enable secret xxxxxxxxx
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
dot11 syslog
dot11 ssid xxxxxxxxx
   authentication open
   authentication key-management wpa version 2
   no guest-mode
   wpa-psk ascii 0 xxxxxxxx
no username Cisco password 0 Cisco
username xxxxxx privilege 15 password 0 xxxxxxxxxx
bridge irb
interface Dot11Radio1
no ip address
no ip route-cache
no shutdown
encryption mode ciphers aes-ccm
ssid xxxxxxxxxxxxx
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 10.20.xx.xx 255.255.255.224
no ip route-cache
ip default-gateway 10.20.xx.xx
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
logging synchronous
line vty 0 4
end
Any help is appreciated
Cheers
Andrew
Bronze
If I've understood you correctly, you are having only problems connecting to AP via Ethernet interface for management? Wireless clients are did not experience any problems when connected to SSID (while AP was in the site). Right?
What is the version of AP IOS?
Actually the wireless clients were having issues. They seemed to  connect to the AP but they could get out to the internet. When I went to  log onto the AP and investigate, I had issues managing the AP via  Ethernet.
The AP Version Details are below:
sh version
Cisco IOS Software, C1040 Software (C1140-K9W7-M), Version 12.4(25d)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 11-Aug-11 02:58 by prod_rel_team
ROM: Bootstrap program is C1040 boot loader
BOOTLDR: C1040 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA6, RELEASE SOFTWARE (fc1)
AP uptime is 16 hours, 46 minutes
System image file is "flash:/c1140-k9w7-mx.124-25d.JA1/c1140-k9w7-mx.124-25d.JA1"
Cheers
Andrew
Bronze
I'm sorry, I had a potential version, but it is now does not fit your case...
Your configuration looks correct ...
I get lost in conjecture, but I would have researched this problem so (unless of course you have the time for it, if not, I would first upgrade the AP IOS to a more recent):
  • is this issue layer 2 or layer 3 - Can wireless client get DHCP ip address? Is the wireless clients can reach the default gateway, each other via AP? Is any issues managing the AP from the same subnet as BVI1?
  • is there any connectivity issues - interface errors, counters. etc...
You cannot use HTTPS file transfer to upgrade to  Cisco IOS Release 15.2(2)JA from previous releases. Because of the image  size for this release, you must use TFTP or FTP file transfer for the  upgrade. Refer to the upgrade instructions at this URL:
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b-chap20-firmware.html#wp1035507
594
