air-ap1131ag-e-k9 - Console problem
Hello.
Whet I connect to %subj console with putty I see only blank screen but when I send break - I see 2-3 lines on device output. Like this:
############################╨Йnщ;vwwьre, C1130 Software (C1130-RCVK9W8-M), Version 12.4(21a)JA2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 02-Nov-09 18:17 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Importers, expoЪ
Settings are 9600,8,1,n,n.
Same cable and Putty works fine with other cisco devices.
Any ideas ?
RGDS
1 REPLY
Hall of Fame Super Silver
Re: air-ap1131ag-e-k9 - Console problem
Well the wireless equipment seem to be a tad but different than the switches or routers. 9600, 8,n,1,n is correct but it almost seems like flow control is still enabled. Have you tried connecting using another laptop? If you have multiple AP's and you get the same results, then its not the AP, but maybe mess around with the settings on putty again. Do you have another program like SecureCRT to test with? Or have you tried the windows default terminal?
-Scott
325
